Discussion topic: Broadband Issues in ME14
Message posted on 16 Nov 2025 07:14 PM
Is anyone else having broadband issues in the ME14 area today. I've been chatting with Sky and they insist there's not a general fault but our local residents Facebook group has a lot of posts with people currently having internet issues.
Message posted on 16 Nov 2025 07:16 PM
Re: Broadband Issues in ME14
@TimJeans
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
If you’re still having problems you may need to contact Sky again to report it.
