Discussion topic: Broadband Hub
Message posted on 10 Jun 2025 10:44 AM
Broadband Hub
Hi, my dog chewed through the power cable for my Broadband router. I've tried several generic replacements, none of which fit correctly causing intermittent power, esspecially if there is any movement of the router. Is there anywhere i can purchase a replacement Sky one?
Message posted on 10 Jun 2025 11:43 AM
Re: Broadband Hub
@Alun13 call Sky who will send you a fulll replacement hub. When it arrives use the power lead from the new hub and return the damaged lead and the new hub to Sky. Instructions on how to send the hub baxk should becin the box or see https://www.sky.com/help/articles/return-tv-broadband
Message posted on 10 Jun 2025 01:13 PM
Re: Broadband Hub
Thanks. I can't find a number to ring on the website. Do you know any numbers?
Message posted on 10 Jun 2025 01:23 PM
Re: Broadband Hub
150 is the free number to use from a phone that has a Sky mobile sim in it or Sky Talk phone otherwise under "Need more help ?" link at the bottom of the page on this link is the number to call Sky on:
Try saying nothing when spoken to by the bot.
