Discussion topic: Broadband Down
Message posted on 12 Aug 2025 06:48 PM
Broadband Down
My broadband seems to be down. Im unable to find a customer services telephone number
Message posted on 12 Aug 2025 06:50 PM
Re: Broadband Down
@Ssheppard
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
