Discussion topic: Broadband Connection
Message posted on 24 Oct 2025 03:35 PM
Broadband not working tried everything
Message posted on 24 Oct 2025 03:38 PM
Re: Broadband Connection
@MandDoc
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
