Discussion topic: Broadband Connection
Message posted on 07 Apr 2025 03:40 PM
The broadband has been cutting off for 15/20 minutes spells for 3 days now. Even though the checker says its OK, there is no Internet connection which makes no sense
Message posted on 07 Apr 2025 03:47 PM
Re: Broadband Connection
@KathyDennisSmit
