Discussion topic: Broadband Connection Dropped
This message was authored by: IAmGroot1
Why has my Internet connection dropped and won't reconnect after I have reset it all?
Re: Broadband Connection Dropped
@IAmGroot1 Take a look at the link below and the lights on the hub say what is going on!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
