Discussion topic: Broadband Boost worth it?
This message was authored by: palsky
Hello Folks,
I am paying about 4 quid more for Broadband Boost every month. I live in a multi storied house and right now I am just using the basic equipment given by Sky. So I am wondering if paying more for the Boost package is even necessary given everything is working just fine without any additional equipment or services?
This message was authored by: JPR007
Re: Broadband Boost worth it?
@palsky It is only really worth it if you claim the extra hardware that it entitles you too.
If the standard kit is working ok for you then there isn't any value in it 🙂
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
@JPR007 wrote:
@palsky
To be fair, if the standard kit would otherwise have been a Q Hub, then a Sky Broadband Hub is better.
Avatar for palsky
In that case, how do I stop it? Also, if I change my mind in the future, can I avail this package again?
@palsky
Broadband Boost is basically becoming obsolete, and replaced by WiFi Max.
