Discussion topic: Broad band
This message was authored by: Jk123456789
Message posted on 24 Jan 2026 07:20 PM
Broad band
I got a new router and it guarantees better signal in all rooms but it is not
Message posted on 24 Jan 2026 07:49 PM
Re: Broad band
@Jk123456789 No router guarantees that so not sure where you ever seen or read that!
Find out more
Message posted on 24 Jan 2026 07:50 PM
Re: Broad band
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
