Discussion topic: Broad band keeps going off
Message posted on 10 Mar 2026 11:52 AM
Message posted on 10 Mar 2026 12:25 PM
Re: Broad band keeps going off
When it goes off have a look at this link that provides information about the coloured lights you may see on the various hubs https://www.sky.com/help/articles/hub-lights-explained-start
