Discussion topic: Broad LOS light is on
This message was authored by: FH6R
Got not internet and the LOS red light is on.
I cannot get through to anly helpline, please can someone call me and update me
Re: Broad LOS light is on
@FH6R
No one will call you. The Sky Community is a customer led discussion forum where Sky customers are available to help other customers. You are NOT contacting Sky Customer Services by posting here. As your Sky account isn't linked to your Community log in name no one knows who you are.
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
@FH6R You need to update yourself, with a LOS red light there is a failure on the fibre home to exchange. Run the service checker via mobile to see if any indication and if sky are currently aware off any issue!
