Discussion topic: Briadband problem
This message was authored by: Home210
Briadband problem
My broadband keeps going  every day unable to conect to my lap top
This has geen going on for two weeks
Please help
Can an engineer call and sort this out
Re: Briadband problem
@Home210  Your post has been moved from the Stream Board as your issue is unrelated to Sky Stream.
No engineer can or will call you on the back of a community post, no one at SKy knows who you are from your co munity login.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
