Discussion topic: Braudband drop out
This message was authored by: Neilgsxr69
Braudband drop out
Hi my broadband has been dropping in and out it's now failed completely my TV runs through the router and there is no connection to the broadband or WiFi
I've run tests on my mobiles and no internet connection
Re: Braudband drop out
@Neilgsxr69
