Discussion topic: Box keeps dropping out
This message was authored by: Angela139
Internet keeps dropping out. Amber lights on box
Re: Box keeps dropping out
@Angela139
There are apparently issues in Essex this afternoon if you’re in that neck of the woods.
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
