Discussion topic: Box has no power
This message was authored by: Essexbirdkel
Box has no power
Hello, our devices say no connection the hub has no power or any lights on, everything is switched on and plugged in however on test my connection on my sky app says the hub is connected?? Please help I have a teenager
Re: Box has no power
@Essexbirdkel sounds like the hub is faulty assuming it isnt. Simply a dodgy mains socket. Call Sky to report the fault so they can send you a replacement.
This message was authored by: peter-marlow+1966
Have you tried  it in a different  plug socket  if you  can, and have you checked the fuse in the plug  itself?
P c marlow
If that doesn't  work then  ring  sky as the hub is faulty  and needs replacing
P c marlow
