Discussion topic: Booster plug won’t reconnect
This message was authored by: DC561
My Sky Max booster won't connect since the system was started up after being off for three days due to a fault on the land line. Have tried all the options suggested
Re: Booster plug won’t reconnect
@DC561 unolug both the podcandcthe hub. Allow the hub to fully restsrt then plug in the pod which hopefully will be picked up.
