Discussion topic: Booster not working
Message posted on 11 Jun 2026 11:08 AM
Booster not working
I have a booster wired in in a different room to the router via Ethernet. It has no lights on, but if I unplug it and plug it in again I get flashing white light, then nothing. My connection to WiFi is incredibly poor - I should be getting full bars as sat right next to the wired booster.
Message posted on 11 Jun 2026 11:15 AM
Re: Booster not working
Which booster is it? Some boosters dont support ethernet backhaul and you would need to pair it to your main hub via WPS.
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
Message posted on 11 Jun 2026 11:24 AM
Sky Max pod booster - installed by an engineer a while ago
Message posted on 11 Jun 2026 11:25 AM
Should there be a light on if it's working?
Message posted on 11 Jun 2026 11:28 AM
The light on the pod goes off when its connected and working. Its a bit counter-intuitive.
Message posted on 11 Jun 2026 11:32 AM
Ok - issue is my laptop is connecting to the router, not the booster. How do I change this
Message posted on 11 Jun 2026 11:49 AM
Sorted - solution was to change the security level (in app) from l3 to l2.
not sure of implications here, but does now work
Message posted on 11 Jun 2026 11:56 AM
The security levels are just WPA2 vs WPA3. Switching back to WPA2 still means your network is secure as WPA2 is still considered a secure standard.
