Discussion topic: Booster not connecting to WiFi
This message was authored by: CB69
The WiFi booster is not connecting to the WiFi broadband box
Re: Booster not connecting to WiFi
@CB69 movecthe booster closer to the hub as it needs a strong signal to be able to work. Normal advicecis to plug a booster in half way between where the hub is and where you need the extra signal. However if the booster wont connect in thecsame room as the hub it is faulty.
This page explains more https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
