Discussion topic: Better speeds brodbands
Message posted on 28 Jan 2026 06:24 PM
I just got sky full fibre, speeds were ok at start but now are really slow, only getting 60 DL and 40 UL.. Is there anything I can do ?
Message posted on 28 Jan 2026 06:31 PM
Re: Better speeds brodbands
@SkyJ1 Start by resetting everything via power off, hub and your devices!
Message posted on 28 Jan 2026 08:51 PM
Message posted on 28 Jan 2026 08:58 PM - last edited: 28 Jan 2026 09:05 PM
@SkyJ1 OK now you have the 100Mb/s upload speed, looks like you have the FF900 sky fibre, if you don't say anything we have to guess, and this is not what the Forum is about!
Things that are better to be known are, white / black sky hub, wireless or wired connection testing, what device are you trying to use... etc
And the first foremost is Ethernet connected device to the back off the sky Hub, device has to be able to get speeds so ie NO laptop connection unless you have mains power on it, then you can speed test to start....
speedtest.net from ookla, preffered app version but web if you must, good enough to get a quick result....
Mobile phone testing then it's a suck it and see what you get....
Low speed's you may have connected on the 2.4Ghz band that's good to 300Mb/s and normally reports around the 220 mark,,, Android phone, wifi bars with a 6 in it, then wifi6 connected to the full speed IF THE phone can do it!
