Discussion topic: Bbroadband down
This message was authored by: Ls231
Bbroadband down
Our broad band has gone down nothing is working getting sick of this especially when you have put prices up yet again
Re: Bbroadband down
@Ls231
You haven’t contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
