Discussion topic: Battery Back-up
This message was authored by: Nik75
Battery Back-up
Can I use a CyberPower DTB24U12V Battery back-up for my sky hub?
Re: Battery Back-up
@Nik75  Does it haave a 3 pin socket on the back?
Re: Battery Back-up
@Nik75
If that's a UPS supplied by BT/EE then it won't necessarily have the correct diameter 12v barrel plug to fit Sky hardware.
Re: Battery Back-up
@Nik75 Yes, you will just have to get the correct cable adapter for use with the sky hub that you are using, and also if you wish to cover anything else involved to keep whatever connection method up for use!
