Discussion topic: Badra Mahamed
This message was authored by: Badra1
Badra Mahamed
I'm having problem with the Internet last three days, my Internet is not working
Re: Badra Mahamed
@Badra1
Use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
