Discussion topic: Bad wifi
This message was authored by: asgoode1234
Bad wifi
Since having sky max WiFi the signal in the bedroom and bathroom drops out my open reach light hub is in the utility room my sky broadband box is in the lounge I connect it with Ethernet cable but WiFi signal is bad
Re: Bad wifi
@asgoode1234
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
