Discussion topic: Bad wifi
Message posted on 12 Nov 2025 10:29 AM
Bad wifi
Message posted on 12 Nov 2025 10:41 AM
Re: Bad wifi
Hi @Rashid1947
It sounds like you may need boosters. You can take a look at this help article to find out how you can get some https://www.sky.com/help/articles/sky-wifi-max
Message posted on 12 Nov 2025 12:16 PM
Re: Bad wifi
Hi @Rashid1947
Another option is to purchase your own Mesh wifi system, costly but gives you a long term solution that works regrdless of broadband provider.
I went with a Eero Mesh system from Amazon to get wifi to all parts of our bungalow, as the Sky Router (and also the previous TalkTalk router) wouldn't reach all our rooms. If I leave Sky for a new supplier in future I will still have my mesh for wifi as most providers routers are not capable of covering even normal sized properties.
Good luck whatever you decide to do.
