Discussion topic: Bad broadband
This message was authored by: Paulmoody
Bad broadband
Signal keeps dropping out
Re: Bad broadband
@Paulmoody
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
