Discussion topic: Bad WiFi
Message posted on 24 Jan 2026 12:13 AM
Bad WiFi
We have upgraded our sky package and have now came across we have worse WiFi. When discussing he package upgrade we explained we had a ps5 as well as 6 other people living here using the WiFi. It will not work. We have tried restarting, resetting, turning on and off and this still doesn't improve. Please resolve this
Message posted on 24 Jan 2026 05:42 AM
Re: Bad WiFi
You haven't explained what you mean by "Bad Wifi" so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 24 Jan 2026 08:23 AM
Re: Bad WiFi
@Emm7 Your upgrade, did you also move to the sky Max hub, that is the white upright version linked below if you need to go look!
