2
This discussion topic has been answered Discussion topic: Bad WiFi signal
This message was authored by: Donnah11
Bad WiFi signal
Im not getting WiFi in some parts of my house
Re: Bad WiFi signal
@Donnah11
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
@SophieHarvey
You might require a second or third one so speak to Sky again if you want them.
This message was authored by: SophieHarvey
Re: Bad WiFi signal
We have the same issue, we have been given a WiFi booster but it still dips meaning call cut out FaceTime go blury as the signal drops befor we have poor network connection
Re: Bad WiFi signal
@Donnah11
@SophieHarvey
