Discussion topic: BROADBAND SPEED
Message posted on 01 Aug 2025 09:42 AM
BROADBAND SPEED
How do I contact sky to ask about my broadband speed I should be guaranteed 299GB but did a test and I am getting 55GB, which is way off what I am paying for and it is anightmare to actuall speak to someone or email.
WHY IS IT SO HARD.
Message posted on 01 Aug 2025 09:47 AM - last edited: 01 Aug 2025 09:48 AM
Re: BROADBAND SPEED
@MarkN2 Your post has been moved from the mobile board as you emntion broadband
Broadband speeds is measure in Mbps not Gbps (the Highest speed Sky offer is 5Gbps on the CF Network)
How are you doing the speed test?
Message posted on 01 Aug 2025 09:51 AM
Re: BROADBAND SPEED
Sorry, I meant Mbps. I did a speed test and this is what I got
Message posted on 01 Aug 2025 09:53 AM
Re: BROADBAND SPEED
@MarkN2 How are you running the tests? Over wifi or on a ethernetconnected device?
What does the mysky app say about your speed?
Message posted on 01 Aug 2025 09:59 AM
Re: BROADBAND SPEED
@MarkN2 You are at least on a fairly high speed package off some sort with the reported upload speed!
