Discussion topic: BB very slow indeed
Message posted on 17 Jan 2026 02:35 PM
BB very slow indeed
I am at present getting 9mb instead of the supposed 64
Message posted on 17 Jan 2026 02:47 PM
Re: BB very slow indeed
@ian4a Is that all the time when however you do the check! Link below will show you what sky thinks, if not it may be a diagnostic test required to check....
Try running the line test here to see if any faults are found:
