Discussion topic: Awful WiFi Speed
This message was authored by: CaraJ1
Awful WiFi Speed
Had sky gigafast for over a week now, initially was good with speeds and range however now it's progressively getting worse, engineer who installed didn't want to put it in a certain room as too much hassle and cables , sounds great for customer service that ! Anyway back to the WiFi speeds usually around 790 to 900 down and 110 up but now on every device it's 230 down and around 40 up , max connected devices are 12 on the WiFi max hub , seems really poor for a device provider to drop speeds that significantly, I've restarted hub as well works for a while then drops back down again. Never had this issue with other providers so I'm guessing it's the router , what can I use instead of the WiFi max hub if it's going to keep causing me instability and slow speeds
Re: Awful WiFi Speed
@CaraJ1 You want to say where the hub is, from before to now, just sounds again like you want to move the hub to were you had it before as the result's then where good!
