Discussion topic: Asus router help with FTTP
This message was authored by: clare+bostock
Message posted on 28 Jun 2024 05:42 PM
Hi guys i have FTTP GIGAFAST
I have a sky hub sr203
And openreach ont modem on wall
What i want to do is ditch the sky hub
And connect ASUS TUF-AX3000 V2
Direct to ont fiber box
What do i do first plug it in sky hub lan port to get asus ax3000 to update first
Or plug it direct to ont straight away
Were i go in settings what do i select
Thanks gir hrlp inadvance
Find out more
Message posted on 28 Jun 2024 07:49 PM
Re: Asus router help with FTTP
Hi @clare+bostock it isnt too difficult to replace a Sky yub with an Asus router this thread explains the settings you need
