Discussion topic: Asus RT-AX58U v2
This message was authored by Pawliq This message was authored by: Pawliq
Asus RT-AX58U v2
Hi
I have router Asus RT-AX58U v2, i have that put on that router instead SKY router. Every 24H router loosing broband and doesn't work until i not connected back Sky Router then conect to Sky router my Asus router. When broband back i can disconnect all routers and connect Asus router directly to ONT box, and will work 24H and i need done everything again.
Anyone have similar experience?
Re: Asus RT-AX58U v2
@Pawliq that is not a common experience but implies the Asus is not set up properly to authenticate the connection. If you do a forum search you should find a number of posts describing the settings you require.
