Discussion topic: Asus DSL AX82U Router and FTTP
This message was authored by: Graham-60
Hi
I currently have an Asus AX82U Router working with FTTC but I am in the process of upgrading for Full Fibre 500 as we have just had an upgrade to FTTP
What I would like to know is can I still use my Asus router with Full Fibre 500 or will I have to swap out to the Sky Max hub which I have been sent but Im not using
Many thanks in advance
Graham
Re: Asus DSL AX82U Router and FTTP
@Graham-60 Sky hub will be required if you are using a landline connection, if not then attach the Asus direct on the ONT, just a few adjustment's to make it operate or reset it and start from scratch, your choice! Search XT8 on the Forum you will find a few setting screens!
