Discussion topic: Apple products with WiFi security
This message was authored by: PJFH82
My apple phone  and pads are showing a security issue, after researching this it says it's because the box doesn't follow new security. I've tried everything from rebooting to forgetting network etc but security issue still remains. I did find on the net it does say I need a white box. Does this mean my black box isn't secure and I need a new white box.
when researching it's only showing information from 2024 or 2025 not for 2026.
thanks, any help would be much appreciated
Re: Apple products with WiFi security
@PJFH82
Have a read of this as about the security settingts as it is this you might need to change:
https://support.apple.com/en-gb/HT202068
Black Sky Hubs use WPA2-PSK wireless encryption by default: the white Max Hub uses WPA3-T.  Sky won't supply you with a Max Hub unless you opt to add the WiFi Max subscription supplement to your Sky Broadband account.
It's  only Apple that thinks WPA2-PSK isn't adequate, and Sky almost certainly wouldn't accept it as a reason for a free upgrade.
Avatar for PJFH82
Thanks, so is the black box secure enough?
@PJFH82
Realistically, yes, unless you've seriously annoyed a hostile state security agency ; )
