Discussion topic: Appallingly WiFi Speep
This message was authored by: WellsWednesday
Why is Sky WiFi so bad it never delivers the speed its contracted to supply . Latest test on my phone 11.1 mbps download and 1.19 mbps upload.
This message was authored by: Me134
Re: Appallingly WiFi Speep
If you mean the guaranteed speed, that's to the hub and not to any wifi device. Presuming you do have the speed you should have to the hub, try the following.
Firstly, unplug the hub for 10 minutes and then reboot, hopefully a channel rescan will find a less congested wifi channel.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
To check on local outages.
To run the local checker.
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
Helpful articles that explain the basics.
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
Link for Sky WiFi Max
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
