Discussion topic: Amber voice light
This message was authored by: Willtaylor1
Amber voice light
Amber voice light and all other lights green on sky router but no WiFi.
service checker shows no broadband connection issues.
not available to find any ways to resolve issues even after turning off the system and resetting.
Re: Amber voice light
@Willtaylor1 an amber voice light can often becsorted by powering down the hub for an hour. However only do that if you use the landline otherwise youcan ignore it if the broadbsnd issirking well.
