Discussion topic: Amber lights on box
This message was authored by: Paulk93
Message posted on 22 Jan 2026 07:47 PM
Amber lights on box
Amber lights on box but sky app says nothing wrong
Find out more
Message posted on 22 Jan 2026 07:52 PM
Re: Amber lights on box
This link explains the lights on the various hubs
Message posted on 22 Jan 2026 08:04 PM
@Paulk93 Either trust the lights which are correct, or the app which is having a guess and will tell you in a couple off hours time, the app does not work the way that you think it does! Do as @Daniel0210 has posted too you link wise!
