Discussion topic: Amber light on router
This message was authored by: Gemma+G
Why is there an amber light in my router
Re: Amber light on router
@Gemma+G
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
