Discussion topic: Amber internet light
Message posted on 16 Jan 2026 01:05 PM
Hi,
The internet light on my sky router is solid amber, I have no internet connection. There have been no changes to my setup. Can anyone help please?
Cheers
Message posted on 16 Jan 2026 01:25 PM
Re: Amber internet light
@Dskelton5 No you need to help yourself!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
and about below this!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
