Discussion topic: Amazon echo generation One
Message posted on 05 Jul 2026 12:03 AM
Got a Amazon echo generation one that connected to my previous supplier perfectly. Can't get it connected to my sky router ?? Any advice or is it death by sky ??
Message posted on 05 Jul 2026 06:19 AM
Re: Amazon echo generation One
@Haztony therecis no reason why any WiFi device that connected previously wont connect to a Sky hub. With Amazon decicescthey often require a reset before they will connect to a new router.
Message posted on 05 Jul 2026 09:09 AM - last edited: 05 Jul 2026 09:32 AM
With a white Max Hub you'd need to reduce the wireless security level from WPA3-T to WPA2-PSK using the Hub settings in the My Sky app.
A Gen 1 Echo is now a decade old and wouldn't be able to handle WPA3 or WPA3-T WiFi encryption.
