Discussion topic: Always losing connection
Message posted on 06 Aug 2026 03:03 PM
Hi There, could you possibly help, I'm constantly losing connection from my hub in my furthest away room where my TV is located and feel an extra range extender would definitely help ?
Message posted on 06 Aug 2026 03:11 PM - last edited: 06 Aug 2026 03:12 PM
Re: Always losing connection
@K69 wrote:Hi There, could you possibly help, I'm constantly losing connection from my hub in my furthest away room where my TV is located and feel an extra range extender would definitely help ?
It may well do.
Which broadband hub do you have? It will be black or white, you can check here for pictures if it helps.
Do you pay for an add on called Sky WiFi Max or anything similar?
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
