1
This discussion topic has been answered Discussion topic: Alternative Power Supply - Lead too short
This message was authored by: CellarDoor
The power supply supplied with the Sky Hub Max only has a short lead that is moulded into plug.
As this is a usb-c supply has anyone had success in find an alterntive usb-c charger so that a longer 2m cable can be attached?
Re: Alternative Power Supply - Lead too short
@CellarDoor you can use an alternative USB c power supply if you prefer with the Sky Max hub. Mine is currently using one supplied by Apple and a standard usb c cable.
