Discussion topic: After upgrade to full fibre, internet keeps going down
This message was authored by: Anton9
I was upgraded to full fibre less than a week ago - so far the internet has gone down 5 times since then. Including tonight. The second and 4th lights on my router keep turning to red. This evening I have switched off the router at the wall - waited a minute - then switched back on again. Eventually all 4 lights turned green and my broadband was returned. It only lasted half an hour - the second and 4th lights on the router are red again. I can't find a phone number to call. This is extremely frustrating,
Re: After upgrade to full fibre, internet keeps going down
@Anton9
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
