Discussion topic: Admin password
This message was authored by: Mattc
Admin password
Hi I've lost my admin password
Re: Admin password
@Mattc  Is this for the router so you can sign into it?
Avatar for Mattc
Re: Admin password
Hi. It is yes
Re: Admin password
@Mattc  If you have not changed it from the default it should be on the back of the router.
What router do you have from the image below
Avatar for Mattc
Re: Admin password
Hi. It's white one the Max Hub
thank you
Re: Admin password
@Mattc the web interface on the white hubs has very limited use as thecsettings have to  be changed in the My Sky app.
