2
This discussion topic has been answered Discussion topic: Adding a tp link archer ax12
This message was authored by: Vern79
I currently have the sky hub 4.2 and Is struggling with WiFi signal upstairs and when using the ps portal . I was wondering if I could piggy back the tp link router to the sky hub to use for WiFi and keep the hub running for the the devices I have connected through Ethernet .
This message was authored by: jamesn123 Answer
Re: Adding a tp link archer ax12
@Vern79
yes you can do this, you would simply be using the TP-Link Archer as your 'Access Point' and then your Sky hub as the main router.
I am NOT a Sky Employee
@Vern79
Avatar for Vern79
Thanks for the reply ended up going with a ASUs router
