2
This discussion topic has been answered Discussion topic: Add devices
This message was authored by: KY53
Add devices
I keep trying to sort up my doorbell. Get as far is entering my sky Wi-Fi password and it keeps telling me it's wrong.
Re: Add devices
@KY53
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as shown on the hub itself so use upper case letting if required.
Re: Add devices
@KY53
Avatar for KY53
Re: Add devices
Thanks for the reply.
Password is correct. I've tried numerous times and always get the same message.
