Discussion topic: Activation not active
This message was authored by: RoryLindsay
Message posted on 28 Feb 2024 12:38 PM
Activation day today, had the text says everything is up and running, router plugged in and all lights green. Can't connect. Sometimes it looks like it connect but then drops off immediately.
Message posted on 28 Feb 2024 02:10 PM - last edited: 28 Feb 2024 02:12 PM
Re: Activation not active
@RoryLindsay Are any off the router lights changing when you see the drop off, and what type of broadband do you have, ie new max, fttp or fttc if you know?
It can also take up to midnight before sky has it sorted there end. So text is not allways correct.
Plus router can also be running FW update.
