Discussion topic: Access denied reference #18 on sky wifi
This message was authored by: RyanWasmuth
Reference #18.1d1e1202.1788003857.4d262d94 is popping up when I try to access either skygo app or access sky.com while connected to sky wifi
Re: Access denied reference #18 on sky wifi
@RyanWasmuth
What device is this happening on so phone, computer etc ?
This message was authored by: Me134
This might be due to a VPN or the iCloud Private Relay on Apple devices. Clearing your browsing history may help as well.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Avatar for RyanWasmuth
Happening on iPhone. Private rely is off and I've cleared browsing history but no affect.
@RyanWasmuth
Are you using a VPN ?
Does it happen if you are on mobile data ?
No VPN and only happens when connected to wifi
It looks like there was or still is a blip accessing this, not that I've experienced it.
Not a Sky employee
