Discussion topic: Access White Sky Hub Router from broswer
This message was authored by: MSHMSH
when I was with Sky before the fibre days, I used to be able to access the Sky Hub and its settings from 192.168.0.1. I have recently returned to Sky on a fibre package and got the White Sky Hub router. When I input the address 192.168.0.1 it redirects me to myrouter.io, and the page has an error "
This site can’t be reached
Check if there is a typo in myrouter.io.
  • If spelling is correct, try running windows network Diagnostics.
DNS_PROBE_FINISHED_NXDOMAIN
Re: Access White Sky Hub Router from broswer
@MSHMSH Not on the white sky Max hub, you have to use the sky app for everything, it's the way for that hub!
