19 Dec 2023 04:23 PM
19 Dec 2023 04:58 PM
Posted by a Superuser, not a Sky employee. Find out more@Richard0097 you can buy RJ11 extension cables with a female rj11 connector on one end and a male rj11 plug at the other. However you maybe better buying a new RJ11 cable of he right length without a join. You can pick them up at most electrical or diy shops. There is nothing special about the cables Sky provide apart from the pretty purple plug. Beware of having cables that are over 10m as speeds can drop. If you have a prefiltered socket with two connectors you dont need a line filter.
