Discussion topic: 4th light orange on router
This message was authored by: Donna1911
Broadband not working
Re: 4th light orange on router
@Donna1911 If you have a fttp service which is the Full Fibre, quick fix may be just disconnect the Ethernet cable back of the hub marked wan, if master socket type try same but will be the DSL connection give it 30 seconds and plug it back in. See how it goes and get back!
